I just got an 03 raptor and it will pull start just fine and runs great. The guy said it needs the starter clutch replaced but the starter button won't even spin or kick in. What should I check to see why it does not seem to get any juice. Just to make sure I am correct when I start it it needs to be in neutral and the clutch lever pulled in.
i just had the same thing happen to me. i am just goin to replace the starter clutch. if you read the thread i just posted called "starter clutch" youll see. and you can start it in gear just pull in the clutch, if your in neutral you dont have to pull the clutch.
ok so if I try to start it like stated and it does not turn over then what should I check. Because if the starter clutch was bad I should still hear the starter spinning. right.
if nothing happens then its probably electrical so check your battery cables
