1 - 10 of 10 Posts
hey i need to put a starter on my 01 i got it loose but whats the best way to get it out of the frame?
Remove the wire from the starter and there are two bolts that need to be removed at the starter base, then pull the starter from the engine..........:)
right i got it loose but there doesn't seem to be a hole big enough to pull it out
You should be able to pull it out of the right side................lots of room............
looks like the exhaust will be in the way
Dang willy, that pic sucks... Not much you could save on that .... SUCKS
I guess that's not to bad considering the looks of it.
so i need to remove the header pipe?
1 - 10 of 10 Posts
