My o2 raptor is having a hard time starting. At times it will just crank and start up with no probs, but recently when I hit the start butttom, it would just wind. I opened the starter/bendex area and it looked fine. The only way it would start is when I put the quad in gear and push it around until the transmission is lock in gear. I' pull the clutch and it will start up but it sounds like a grinding noise. I have not opened up the flywheel cover area yet. Where should I look into first?
Thanks for any response.
alex
alex
