1 - 11 of 11 Posts
ok so me and a buddy just got a 03 660 with a 686 kit, full exhaust, and a k+n... the problem is it wouldnt start when we got it so we took it to the local shop. guy put new battery, new relay, new starter, adjusted the valves, and cleaned the carbs. he did all the work on my last raptor as well, so i trust the guy... were plannin on riding trip tomorrow but when we start the quad it idles a little funny and when you hit the throttle it backfires like a m16...any idea?
carb issue sounds like its lean? does it work better with choke on a little? if so its your carb or maybe fuel line is clogged and fuel shut off valve plugged off? first thing to try take fuel line off and see if fuel comes out in nice stream if not take tank off its plugged or if thats ok carb issue? let me know what you find
Most likely the park brake sensor is stuck on, or is on............
This turns on the park brake rev limiter...........
So say we have two other buddies that know everything and they ripped off the parking break yesterday and put on a block off plate....how do I go back and fix it
Unplug the park brake switch from the harness, just follow the wire to the main harness and unplug it, also seal it, any moisture or mud that enters that connector, can turn on the park brake rev limiter.........:)
Git-R-Done
Git-R-Done
Git-R-Done
Good to here, now go ride......
Doesn't ANYBODY ever read the stickies anymore? ESPECIALLY - "Most common 660 problems"?
1 - 11 of 11 Posts
