Thanks, 02six - if you could connect, check the RPM limit, then disconnect and check again, that would be very cool! Maybe too much work... but I can ask, can't I?
You should start your own thread on your problem.I’m having problem with my battery losing charge after so long of riding/starting, could this be a stator issue? I can start the bike, disconnect and remove the battery and wile motor is running, put a test light on the two cables and it is dim but does light up. Should it be putting out more amps then that? Or do I have something else draining the battery?
The regulator controls the output of the stator, (alternator). So if you run into a situation as you describe and unplug the regulator you will be driving on the power supplied by the battery only.not trying to hijack. but lets say you're in the woods and no cell phone, and no tools. quad shuts off due to no spark, and you unplug the rectifier and all spark returns. can you drive out of the woods to the trailer? basically, can you unplug the rectifier and drive it?
if so, is the rectifier on these quads JUST for charging? or do they serve any other purpose(s)?
