But if you fhen cut the red wire as described above, and re-connect the regulator, you are good to go.
To answer your question, yes you can drive quite a ways with the regulator disconnected - just your battery will slowly discharge as it is no longer being charged.... (Don't use headlights!). With the red wire cut, you can reconnect the regulator and all is good forever.
