I'm new to the forum, the 660's, but not to four-wheelers. I recently bought a 01 with a new 02 motor. This thing is wickedly fast but I do have one issue that I need help with. Under acceleration it drifts to the left, which of course I correct to keep it straight, and when you let off if will shoot to the right. It's just a little bit to squirrely to be comfortable. Any ideas as to why it pulls so hard to the left under acceleration? Other than that I love this beast.
Welcome to the forum!
Only a few possibilities -
1) bent front suspension (a-arm or frame) or way loose front spindle bearings
2) Loose axle carrier / worn axle bearings / loose axle / loose rear hub / loose rear wheel
3) worn swing arm bearings
4) one rear tire very low pressure
I may have missed something, but I'm sure if I did, others will fill it in.
Also check your steering stem & make sure your nut on the bottom is tight.
