Hello guys, I want to ask you how do you take off your steering steam seals from the lower bearing, I had tried with some screw drivers, but I couldnt make it, I dont want to just cut it and throw it out because I cant find a new seal replacement in my country for sale (yes its sound ridicuolus, but it is what it is) so I need to keep the stock seal in good shape. The bearing its worn out, it have some play in it so I already have the new bearing replacement and want to replace it.
Another question is how much millimeters have the lock nut for the bearing under the upper seal? its 30 or 32mm?
Any easy way to fix a small bend on the steering stem? I dont want to buy a new one, its in good shape it only has an small bend.
Thank you guys!
Thank you guys!
