1 - 11 of 11 Posts
I've heard the Steering Stem bearing is a standard bearing. Anyone know the bearing number?
Just checked....amazingly enough the manual does call two pieces of plastic with a hole cut in them for a the stem a "bearing".
No idea on the standard number or even if it is indeed a standard, but here's a bump none the less.
Discussion Starter #3
I'm looking at #31-33
30-- 93306-20331-00 BEARING $13.43
31-- 93102-25081-00 OIL SEAL $4.37
32-- 93102-25099-00 OIL SEAL $4.37
33-- 5GT-23872-00-00 HOLDER, BEARING $8.54
Modding Maniac
im in the process of trying to replace that bearing. id like to slap the shit out of the guy that engineered that fine piece of work on the bottom bearing.
I'm also doing mine but came to a dead end until I get into town tomorrow to get something to remove that retainer.... what a pain in the ass!!
I found a big nut that fit in the retainer and welded another nut to it,then used a breaker bar and socket and it came right out!!!! Good luck! :D
Cheers man, thats what I was going to do... cant think of any other way, except buying a 30mm allenkey
That works....If you cant weld, try a Large bolt and two nuts on it, that is how i got my wifes off her 350 after she bent the frame....:eek:
Just done mine bearing was a 6203!
1 - 11 of 11 Posts
