Need a giant Nut welded on a giant bolt to access the steering Stem Bearing, and No the Sprocket should NOT have any play in that direction, just tighten your Axle nut and that problem should be solved
pull the top seal out, a nut screws in from the top, a 1-3/16" nut should fit inside, might be tight, and unscrew it. it's a backwards nut hex inside and thread outside
