1 - 1 of 1 Posts
I just went to do some things on my raptor 700 for racing which starts next week. I pushed the throttle lever and noticed it was stuck wide open. Took the cover off the throttle lever on handlebars and everything was fine in there. So i thought i would have a look where the other end of the throttle connects which goes into throttle body. I took that small 3 screw cover off. Everything seemed ok. So i pushed the plate which holds cable and it unstuck. So i pressed thottle lever again on handlebars and it stuck wide open again and didnt release. I sprayed WD40 but didnt seem to do anything. So i disconnected cable from behind plate on motor. And pushed small plate and it is still sticking and not releasing. Not releasing from full throttle back to idle posistion. has anyone else had this problem before. I took small plate off that connects throttle cable and spring but everything seems ok. Well i know its nothing to do with throttle cable. Might be the spring tension gone weak but i doubt it. I did notice though while i got plate and spring off i cant turn it by hand. have to get a pair of pliers to turn it. Is this normal or should u be able to turn that butterfly easy. Any help would be much appreciated as i need it working by next weekend.
1 - 1 of 1 Posts
