Where exactly were you spraying the WD 40 at? I'm having a heck of a time getting mine out. ThanksYellowistheFastest said:I had same problem and pulled and pulled warmed it up heated it up and nothing worked. Finally sprayed some WD-40 on it let it sit a few minutes, grabbed the edge with some vise grips and twisted and it came right out.
rich807 said:I pulled mine out today no problem. I just took a heavy duty set of pliers with low profile teeth, clamped on the bottom of the insert, and yanked hard a couple times with a slight up and down motion and it came right out.
