Hello everyone
I decide to help you if you need that and put here some stock parts , maintence for the raptor 350 that you can buy from eBay if you need something that not on this list..reply to this topic and I try to add :)
Oil Filter
OEM:
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/Yamaha-Big-Bear-Moto-4-Warrior-Kodiak-Raptor-Grizzly-Wolverine-oil-filter-OEM/183337280386?epid=1911871396&hash=item2aafc0e382:g:rS4AAOSwbYZXUIwH:rk:4:pf:0&vxp=mtr&campid=5338413104&toolid=20008
Non OEM
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/Oil-Filter-For-Yamaha-YFM350-Warrior-YFM350R-Raptor-YFM400FW-Kodiak-HF142/111032104125?epid=1291204355&hash=item19da0774bd:g:seQAAOxyTyBSYI9B:rk:2:pf:0&vxp=mtr&campid=5338413104&toolid=20008
Air Filter
OEM
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/NEW-YAMAHA-OEM-AIR-FILTER-1UY-14451-00-RAPTOR-WOLVERINE-WARRIOR-350/312066694681?hash=item48a89fde19:g:N~cAAOSwhfdaguNv:rk:2:pf:0&vxp=mtr&campid=5338413104&toolid=20008
Non OEM
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/Air-Filter-For-ATV-Yamaha-Warrior-350-Wolverine-350-4x4-Raptor-350-Grizzly-660/263634398634?epid=868949780&hash=item3d61d5adaa:g:dx8AAOSw6rda4FZ8:rk:1:pf:0&vxp=mtr&campid=5338413104&toolid=20008
NGK SPARK PLUG
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/New-NGK-Spark-Plug-for-YAMAHA-ATV-Quad-YFM350R-Raptor-05/291089567931?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649&campid=5338413104&toolid=20008
OEM (YAMALUBE) ENGINE OIL 10W40
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/Yamalube-All-Purpose-4-Four-Stroke-Oil-10W-40-1-GALLON/110709484692?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649&campid=5338413104&toolid=20008
Piston Rings Stock Size (83MM)
OEM
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/401232773611&campid=5338413104&toolid=20008
Non OEM
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/Brand-New-RAPTOR-350-Piston-Rings-STD-83-00MM-FIT-YAMAHA-2004-2012/163590476456?hash=item2616c092a8:g:AgUAAOSwAYtWG4pB&frcectupt=true&campid=5338413104&toolid=20008
Valves
OEM
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/NEW-OEM-EXHAUST-INTAKE-VALVES-VALVE-SET-FOR-YAMAHA-WARRIOR-GRIZZLY-RAPTOR-350/372373158134?fits=Model%3ARaptor+350&hash=item56b32b78f6:g:F70AAOSwpJdbT1z7:rk:1:pf:0&vxp=mtr&campid=5338413104&toolid=20008
Non OEM
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/Kibblewhite-Intake-Exhaust-Valves-Yamaha-Warrior-Raptor-Wolverine-YFM350-YFM-350/191816352482?fits=Model%3ARaptor+350&epid=1929936923&hash=item2ca92542e2:g:DLEAAOSwmrlU1LmO&frcectupt=true&campid=5338413104&toolid=20008
Timing Cam Chain OEM
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/D-I-D-Timing-Cam-Chain-OEM-Yamaha-YFM350-See-Fitment-Chart-94500-02090-00/302425198974?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649&campid=5338413104&toolid=20008
Carburetor
Complete carb Non OEM
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/Carburetor-FITS-YAMAHA-Raptor-350-YFM350-2004-2012-NEW-Carb/280802448697?fits=Model%3ARaptor+350&epid=2098201299&hash=item4161215539:g:pUoAAOSwDk5T6khZ:rk:1:pf:0&vxp=mtr&campid=5338413104&toolid=20008
Rebuild kit Non OEM
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/All-Balls-ATV-UTV-Carb-Rebuild-Kit-YAM-RAPTOR-350-2004-2013-YAM-RAPTOR-350/372443268442?epid=239160417&hash=item56b759455a:g:NroAAOSw15ZbpC8W&frcectupt=true&campid=5338413104&toolid=20008
Rear Sprocket
OEM
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/Yamaha-OEM-Part-5TG-25438-10-00-SPROCKET-DRIVEN-38T/192424754677?epid=1911873539&hash=item2ccd68bdf5:g:CmUAAOSw7W1bx26p:rk:1:pf:0&vxp=mtr&campid=5338413104&toolid=20008
Non OEM
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/JT-Rear-Sprocket-38T-520P-JTR1857-38-Steel-Yamaha-YFM-350-R-2008/303086156692?hash=item469157bb94:g:hesAAOSw0lhcfz5G&frcectupt=true&campid=5338413104&toolid=20008
Front Sprocket
OEM
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/Yamaha-OEM-Part-93834-13030-00/192861363045?hash=item2ce76edb65:g:jL0AAOSwddpcjtvK&frcectupt=true&campid=5338413104&toolid=20008
Non OEM
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/JT-Front-Sprocket-13T-520-Pitch-JTF569-13-Yamaha-YFM-350-RA-Raptor-2011/302835490737&campid=5338413104&toolid=20008
Drive Chain OEM
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/Yamaha-OEM-Part-94581-87098-00-CHAIN-DID520V-98L/192520809027?epid=1743691674&hash=item2cd3226a43:g:1PoAAOSwv5xbx1yj:rk:1:pf:0&vxp=mtr&campid=5338413104&toolid=20008
Rear Sprocket + Front Sprocket + Drive Chain (Stock Size) NON OEM
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/520H-Heavy-Duty-Chain-Front-Rear-Sprocket-Kit-YAMAHA-YFM350R-Raptor-2004-2013/311835044546&campid=5338413104&toolid=20008
Tusk Top & Bottom end engine Gasket set
https://rover.ebay.com/rover/1/711-53200-19255-0/1?mpre=https://www.ebay.com/itm/Tusk-Complete-Gasket-Kit-Top-Bottom-End-Engine-Set-Yamaha-Warrior-Raptor-350/302214406972?fits=Model%3ARaptor+350&epid=1529942675&hash=item465d61e33c:g:SV8AAOSwE0JY~3jg:rk:1:pf:0&vxp=mtr&campid=5338413104&toolid=20008
If something wrong/not accepted or link is invaild you are more then invite to tell me
if its good and helpful you can stick it to this forum. Thanks
Great job. I made this a forum sticky.
