1 - 10 of 10 Posts
I cleaned my Carb Today with (Carb Cleaner and then Air them out with air spray)... I took my Gas tank off and cleaned it out too, as thier was some Dirt inside it and rocks! So I took the hose inside the tank and Sprayed it all out and Waited till it was all dry inside to put it back on.. I went to the Gas station today to get gas..I changed my spark plug, Now i Dont no why it wont START the ATV is FRUSTURATING me.. someone help!!
did you turn on the gas???? rock the quad a little to get gas all through the carb, thats what I do when I take off my carbs
I rocked it abit, And I try starting it and nothing and the gas is on... When i was trying to start it it POP (backfired)? WTF?
maybe one of the jets could have got clogged???
I just cleaned the jets and carb aww this thing is frusturating me ALL i want is it too fire [email protected]
when you blew them out you could have blown a liitle piece of sand or dirt into one of youre jets
Whats the LOUD POP from the Exhaust?
could be a lean or a rich pop, probably lean. never use compressed air to blow out a carb, like they said before you will blow a pice of dirt into somewhere it shouldnt be. i would think though that your float is stuck. try tapping it LIGHTLY on the carb with the handle of a hammer and see if it will start then
Whats the proper way to clean the carb, just spray the carb cleaneron it and leave it?
With the pop when you are trying to start it, it is most likely a rich pop. Meaning your overloading your cylinder with gas. Hows your spark?
1 - 10 of 10 Posts
