I saw a thread asking about swingarm plates and it got me thinking...I took mine off because the inserts were about to fall out. When the swingarm mounts start coming loose is there a good fix for this (other than going aftermarket swinger)? Drill holes all the way through the swinger and run bolts and nuts?
You could probably drill and tap them out a little bigger. I use blue locktight to keep mine in and tight. =)
They look like some sort of press in insert. Haven't tried to take them out yet they seemed really loose and about to fall out.
