Just wondering if switching from my sparks big core(ceramic coated) to the LTE dual setup would be worth it? I'll be going built here pretty soon in the next few weeks more then likely if I dont pick up a 700.
rt said:More than likely you won't even feel a difference with the mods you have. When you uncork the motor ..(port, cam, piston, and even carbs) some more you'll utilize more of the pipes (lte) potential, and go to an area where the sparks will not be as efficient, especially if you go big bore ,or stroker.
