jpok69 said:
could anyone explain to me how to check if the carbs are synchroned and how to synchronize them??
Are you having problems?
For starters, carbs jets main jets are staggered, from the factory the main jets are 140 in the left, 145 in the right carb. The right feeds just a bit more than the left carb.
~Brian
Only thing in the manual about syncing the carbs is to use a drill bit to check the clearance between the butterfly and the body of the carb. There is an adjustable coupling between the carbs that is adjustable. Being a single cylinder what do you hope to gain?
