1 - 14 of 14 Posts
So it's time to finally time crack the motor open and see what I REALLY did to the tranny. While I'm in there, I'm gonna toss a few goodies in, for good measure. What I'm looking for is any advice, tips, heads up, opinions, etc...
It's not gonna be real radical, but it should be a lil healthier.
Here's a list of intended parts: the hotrods 719 kit, The crank/rod combo and the recommended Vertex piston. Stage 3 cam/spring kit. Yukon HD tranny gears.
Barker in frame duals with the recommended jet kit. For now I'll stick with the stock carbs (FCRs come later) I guess part of what I need to know is, will the stock carb be enuff with the jets? My CPU is a BigGun over rev..I don't really know much about that. I'm sure a carb/cpu upgrade will help, but that will be later. Is it ok to bore my cylinder, or do I need a sleeve? What's an average price for porting? Oh yeah, I also got the K&N filter and the billet deal it plugs into, w open airbox. I'm trying to keep the budget to around 2 grand.. Note I say "around" which is a fairly loose term here...How loose? depends on my actual refund..should know more 2mro. If anyone has this combo I speak of, or close to it... what can I expect over stock?
You can bore it up 102mm. Is there a reason for no head work. I did not do any do to time constraints. I had to go out of town for work for a month and wanted it DONE so when I came home for a weekend I could go ride.
Discussion Starter · #3 · (Edited)
Well, I'm not sure how much headwork cost, I know it will bring it to life, anything to help it breathe is free horsepower(except for the cost of the work lol). I'm not beyond pulling the head a few times, I just wanna do the interior work while I got it open that far. Headwork is DEFINITELY in the future. Speaking of, do you know if the vertex piston will accept a larger valve without machine work on it? Also, it says this pitson is a 9.2:1 CR..is there a way to bump that up? IS there a thinner head or base gasket available? Would this possibly bump it at least .8? It is a 102mm piston, so I'm good there. Can the combustion chamber be welded on to decrease volume?
the stroker crank will take it up about .75 on the compression. I used a CP piston when I did mine. Will be breaking it in friday or sat since I finally have everything to finish the job. then it will be off to the dyno.
The vertex says it must be used with the stroker crank, but advertises 9.2 CR ...wouldn't that be with the stroker taken in account?
Have no idea. I just got mine running and took it for a 3 mile ride tonight.
The barker cranks bump it up in compression but they don't use a stroker piston. The HR cranks don't give the extra bump due to it being figured already. You can get a JE 11:1 or a CP 10.5:1 stroker piston for about 200. For 250 you can get a 13.5:1 Kenz piston made by CP to. There are a few options out there.
thanks dog, I need to consider I'll probly only runnin 91 octane, so I figure around 10:1?
U also need to consider dynamic compression and static compression. Google it. Then consider your talking about a stage 3 cam.
I ran a 11:1 JE on a HR stroker crank with a stage 3 cam and has no issues running 91-93. I even ran 87 a few times and didn't have any issues but you should be fine with any of those piston choices.
coolbeans, If I go any wilder there is a small airport just down the road...they sell av-gas...
Av-gas is made for SLOW RPM engines and to run at a higher altitude, plus it has lead in it. That is why it is called low lead.
Discussion Starter · #14 · (Edited)
Not that I doubt what you say, but HOW slow are you talking about? ...Oh...OK I see now... I just wiki'd the answers.
1 - 14 of 14 Posts
