1 - 20 of 28 Posts
Recently got a pro armor kill switch and am trying to find out which of the 2 wires plugged into the coil does the switch connect to, or does it matter on just either one. Racing at an indoor mx track and would like to hook up this time.Thx 4 help! J
Check ProArmor's website. I believe they have a harness that was specifically designed to plug into the wiring harness.
Frank
Ok im still looking for some insight on the rt way to connect these wires if anyone knows. The harness deal from the site i already made that took like 5 mins. But i plug one into the pos. terminal on the coil , the other went to grnd and I blew the igniniton fuse. The kill did work but bcuz of blowin the fuse. If anyone knows this or has a better way like to the lean angle sensor or smthn that would be great.thx J
Ive got one on mine(pro armor). The ground wire I just bolted it to one of the bolts in the frame and the other slices in line with the wire coming from the stator to the coil. The goal is to ground the stator wire to shut the engine off. Thats it, done.
Just an FYI-
I also have mine setup to kill the power to the fuel pump.
Would hate like hell to fall off, have it "wreck", and catch on fire due to the pump running with the key "hot".
Thats a pretty good idea as long as I can find the rt wire for the fuel pump. Now that wont hurt nothing w the fi right? My buddy read smthn about this switch hookin up to the coil isnt good for the ecu or the fi or smthn. Is that just bs.
there is a blue and yellow wire coming off the stator that is the coil signal wire that is the one you want.
Ok I think im pickin up on this, I was just figuring the ignition coil wires were running to the stator coil for the ac magneto, but now im thinking I just need to deal w the stator wire like your saying and not deal w the ignition at all. Ok cool tks!
Just for a point of interest guys there have been a lot of problems with people wiring up kill switches to there coils on the 700 blowing the ecu by giving it a spike backfeed
you need a normaly open switch from any electrical shop so that the curcuit is made with the teather in and broken when its out and wire it into the kill button on the bars. you wont get a problem :thumbsup:
Does anyone know if the tether information you have been discussing holds true on a raptor 350? I understand that the 350 is not fuel injection, but is the wire the same color? thx.
I also just bought a pro armor kill switch and I wired it to the coil just like how the instructions said. I have not heard anything about this blowing the ECU up. Have very many people had this problem?
splice into the orange wire.... the red one will blow a fuse.. trust me i found out the hard way that is it, and havent had a prob. w/ it
on the coil, sorry forgot to put it in the first reply..
Yeah I found the red wire issue out the hard way also. Just wondering because someone above said that it could blow the ECU if you wired it into the coil. Kinda worried me. Anyone have some info on that topic?
Where is the best place to tap into the stator wire? Is this safer then the coil wire as far as spiking the ECU?
no it wont spike it if you tie into the orange wire on the coil. just DO NOT tie into the red, if it doesnt blow a fuse it will blow the ecu..
mine is on the coil and i havn't had a problem in the 5 months I've had it (besides pulling it out doing doughnuts once, i felt retarded)
1 - 20 of 28 Posts
