I've just installed the three mods, HMF full exhaust, k/n intake and the PCIII. I have the 15t sprocket ordered but it hasnt come in yet. I went and rode it after I uploaded the map for my setup, and when I let off the gas I have a backfire. I'm not to sure what to change on the pcIII so if you could direct me accordingly that would be great. I think I was expecting a little more out of it, but could it be since im running through the gears so quickly it doesnt seem as fast as it should? Anyways it sounds great and I love the look of the exhaust..
What map are you running? One off the site? Check the first column on the PCIII, the 0% throttle, In the 1250-2250 rpm range. What are the numbers, if they are zeros, make them 2, 4 , 6, 6, 4. See how it runs
my suggestion is try changing those to 4,6, 8,6,4. Then see if it pops.
