If that's all that is wrong... install the correct spring and, perhaps, replace the cable. 1/2 hour later, you're done.
For assistance, download the service manual from the sticky at top of this section.
VIP
You have a few issues going on. First, you are missing the return spring that goes on the pull rod shaft. You have the incorrect bolt that is supposed to hold the pull rod in place and the gears on the bottom of the pull rod are not engaging which is why you have no clutch. Throw away the spring that the PO installed and order the following parts.
Spring 90508-20016-00
Bolt 90109-06418-00
Washer 90430-06014-00
Click on the part numbers and it will take you to Partzilla with pictures. You can see the bolt has a shank on the end that engages a groove in the pull rod which holds the rod into the case.
Once you have the parts, we can help you with timing the pull rod lever and adjusting the cable fee play.
