Should I go with a bored TB? +2, or +3?
Hey, I've seen a few people here running the bored throttle bodies but I haven't read any disscusions on them. I've seen TQS offers the service at a reasonable price. What kind of benefits can one expect from this mod as in HP tq increase and rideability. Also should I go with +2 or +3? My mods are barkers, FCI w/box, and this winter doing HC2, 11:1 piston and either PC5 or msd blaster. Thanks.
+3mm, ride ability is same as stock. Very very minimal loss on the low end if any. You should see a couple hp increase especially on the high end of the rpm range, throttle response is a bit snappier, these motors respond very well to bigger throttle bodies which leads me to believe they are very corked up from stock
We havent seen much losses in the lower RPM with a +3 over a +2mm. So basically bigger top end gain with the +3mm and same lower end. I'd go +3mm for this very reason.
I got a fresh batch of cores in stock today. Both years.
I have a +2 on my 07, the only reason I have that is cause I bought from a member used and the price was right. If I were to do it over again, I would get the +3.
