1 - 10 of 10 Posts
Hey guys I was wondering if anyone could give me some insight here. How do you wind this spring up to reset tension on it? As of now there is now tension and the valve does not snap back after opening. I know it needs to be wound but im not sure how you go about doing this. Thanks for any and all replies it is greatly appreciated.
Discussion Starter #2
I have searched all over the net and I have the service manual but I cannot find one thing about this anywhere. I have tried everything to get tension back on the spring and i'm lost. I'm sure someone has completely taken the carbs down and got them back together. By the way these have been the worst carbs I have ever had the displeasure of working on.
Discussion Starter #4
Thanks for the reply I just need to know how you wind it up to put tension on it. I can't find this anywhere I have tried every way to wind the spring up and it just doesnt work out.
These mikuni bsr carbs are vacuum operated, part number 18 in that microfiche is not designed to be "re-tensioned" as there are no keepers holding it in place at the top and bottom, it can only be replaced. If that's not the spring you're talking about, please cite which one you are.
Discussion Starter #6 (Edited)
Its the spring that goes to the part besides part number 5 on the link you posted. The spring is not listed on anything that I have looked at. Its not the throttle valve i'm talking about sorry im not sure of the name of the part i'm talking about the spring is in the housing on the carb where your throttle cable goes I gues it could be called the throttle pulley maybe?
Springs are fairly simple, if you wind it tighter it will give more resistance. If the mechanism for the securing of this spring holds both ends in place keeping the "re-wind" intact then you will get a change in resistance, if it does not then you will not. Other carbs like the FCRs I used can be tweaked in this manner or the spring itself can be replaced with one of a different resistance.
Are you sure this spring is your problem? I ask because in the 10 years this forum has been online I've not seen anyone else cite a need to repair, replace, or rewind it and there are other possible reasons for malfunctioning carbs.
Discussion Starter #8
The spring has no tension on it. I was in the process of taking the carbs completely down and got to that point and disconnected the spring to further take apart the carbs. Then I decided not to go that far and now the spring is just sitting in there. Like before I did this that spring had enough tension to snap back when you pulled the throttle to open the brass valves in the carb. I'm sorry I do not know technical names here for the parts. I just can't get it back to how it was before the disassembly. I could post pics later when i'm back home if that would be of any help? Thanks though for your replies I greatly appreciate it.
I think I have a better grasp of your problem now, it's not that you need to modify the part it's that you took it apart and are now unable to put it back together. I sympathize, but unfortunately I cannot help as I have never had to disassemble that section of the factory carb. I hope someone else has and can offer insight on how to re-install it.
Discussion Starter #10
Thanks for your replies im not trying to modify it im just trying to get it back together how it was the spring somehow has to be wound up to make tension on it to close the brass valves in the carbs im just not sure how you go about winding it up to get tension back on it I have tried every way possible. If I could find how somone else did it that would better help me or maybe a vid on how to do it.
1 - 10 of 10 Posts
