would a bent tie rode make it pull to right?
A bent tierod would make you pull a little, but if your really pulling, its most likely a bent steering stem.
im not to sure if it would be the steering stem...mine is bent up pretty good and it doesnt pull...check your alingment....tire wear and pressure... easiest way for alingment is a piece a string...
