1 - 10 of 10 Posts
just bought a new chain and cut it to size, it is a little loose and i cannot find the means to tighten it and I do not have my manual that came with the bike can someone please help me out :help:
there should be two nuts on the right side (you will have to go throw the holes on the claper) back the nuts off then on top of the swing arm there
are two adjusting bolts turn each on the same number of times to keep every thing stright.
so i loosen those on the side then tighten the ones on the swingarm
while the tires are on the ground or not?
I am looking at the nuts on the side and all it is, is a regular nut and one of the nuts is missing
this is how the manual says to do
Adustment steps
loosen hub nuts (on the side)
loosen the locknuts(on the top of swing arm)
turn both adjusting bolts
i did it with the wheels on the ground but the time be for that i did it with the wheels off the ground
you also have to spin the rear wheels several times to find the tightest point.
Thanks Guys you helped me with the same problem! u guys rock :thumbsup:
1 - 10 of 10 Posts
