Its time for an oil change and I was wondering exactly how much oil do I need and does Royal Purple make at atv oil that works for the raptor?
It's actually 1.96 qts.2.43 quarts when you change the filter too
I thought this was the 700 section too! Ha ha. Oops.Those are the specs for a 700. They may be different for a 660. Sorry for the confusion. I didnt read the OP's section before I posted that![]()
I'll probably end up doing that anyways. I can't find a dealer that carries any of the other stuff mentioned in this thread. My local yamaha shop has plenty of yamalube.I've always been told not to run full synthetic in anything with a wet clutch...I've always used regular Yamalube in my Raptor 660 and Roadstar 1600 without any problems. I usually need around 2 1/2 Quarts with filter change to hit the full line on the 660 dip stick
Question is, who always told you this, and what was their true understanding of oil and its chemistry... there's a whole lot of old wive's tales and voodoo out there being passed along as gospel.I've always been told not to run full synthetic in anything with a wet clutch...I've always used regular Yamalube in my Raptor 660 and Roadstar 1600 without any problems. I usually need around 2 1/2 Quarts with filter change to hit the full line on the 660 dip stick
