1 - 11 of 11 Posts
In the upcoming weeks I am going to be purchasing some ITP holeshots but I want to get them with wheels so I can easily take the stockers on and off when I please. Does anyone know a good site to get them with the wheels? I don't need fancy wheels just something simple... 8)
How do I tell what wheel size fits to what tire size? I want to get ITP holeshots with some not so expensive wheels....
At rockymountain, you can put in what quad you have, and it will show all the available parts and accessories (including wheels and tires) for you Raptor. The site should be pretty self-explanatory. Hope this helps.. :thumbsup:
what I'm still trying to figure out is when it says like 10x8x11 or so, how do i read those numbers which one is for height, width, ect?
:help:
height X width X rim
Stocks are front 21x7x10 and rear 20x10x9
alright so just match the width +rim to the rim's width and height........... I just wanna make sure not to screw up the order
E bay - yamaha of troy- Best price combo I have seen for holeshots (HD's , GNCC's, XCT"s, or standard) on .190 ITP wheels $399 plus shipping. Check it out.
Stock front tires are 21x7x10 (21" tall by 7" wide for a 10" diameter wheel). The stock front wheel is 10x5 (10" in diameter and 5" wide).
So the last number in the tire size must match the wheel diameter, or it will not fit. The middle number in the tire size (the width) must be wider than the wheel. For example, the stock tire width is 7" and the stock wheel width is 5". If the numbers are the same or backwards, then the tire will not seat properly on the bead.
Any tire height will fit on the wheels as long as the tire width and wheel diameter are correct as noted above. i.e.: You can run 28x12x9 tires on the stock 9x9 rear wheels if you wanted.
If you order a different size wheel (a 10x10 rear wheel for example), just make sure your rear tires are at least 11" wide and are for a 10" wheel (??x11x10)
1 - 11 of 11 Posts
