my 660 2003 has 23in front and 21in rear razzar2 they are great but not good for mx racing. i would like less agresive and lower profile tires so i can realy slide the bike around easier. looking for rims and tires so i can swop them easly when needed how low profile can i go, can i use smaller rims and can i use same set up as 450s
A smaller rim is a bad idea if you're trying to slide around and have a lower profile tire.
Most of the MX racers are running a 20" front/19" rear or a 19" front/18" rear on the raptors.
what maddog was saying was, you dont want an overly small rim with a big tire, with lots of sidewall. The sidewall in sliding will "roll" and grab and will try to launch you, or might roll off the bead if your not using beadlocks....
