What is the measurement for toe-in adjustment? I had dropped the front end WAY down for ice racing and had to adjust the toe for that heighth, now she's back up and I'd like to get it right for summer.
Also what tire pressures are y'all running front and back?
toe in should be 2 - 12 mm w/ tires touching the ground... air psi i run is like 5..
Thanks! I knew 1/8" was standard on big trucks but wasn't sure if that carried over to ATV's or not.
