and found they still have stock jets in them..i guess thats why its running like doo dooo..anyone know whats a good starting point on the jets to use..i live in dallas tx.. i have full fmf exhaust a k n filter with holes drilled in the top of the lid..im guessing its runnin lean right now and not getting enough fuel..im gonna order the dyno jet stage 2 kit..anyone have any suggestions or will the dyno jet instructions list jets for certain mods
thanks
it should. not giving it enough fuel will make it run like a turd. pull the plug and see what color the end is..... the end that goes into the motor.
If you're using the dynojet kit, the 155/160 recommendation will not be right, those are mikuni sizes. DJ jets are labeled differently, you will probably need 144/146 to start with, but the instructions should give you a good starting point.
