That's what I've always usedBJH said:A Hammer and large straight blade screwdriver works great. Sounds crude but the spanner is a pain in the ass and expensive.![]()
first you need to loosen the other nut, did you do that first? loosen the top one, then tighten the bottom one, or loosen, depending weather you want your shock stiffer or softer..Machy said:I've tryied that method and could only get it to go up one notch, afterthat it is too tight to go anymore......![]()
