1 - 1 of 1 Posts
When you guys re-set your TPS (pc III usb) Do you do it while the bike is running or just on but not running. Also With the headlights on or off? Each way you do it the closed/open settings will be diffrent then if you would have done it anyother way. I was messing with mine tonight and reset again with the lights on and got a 6% open when it was closed all the way with the lights turned off. It would only open to 94% when it was opened all the way (should have been 100%) I THINK I would also get a 1% open when I set it while the bike was on but not running. Then while it was running I would get the 1%. :crazy:
1 - 1 of 1 Posts
