I am getting some goofy numers on my power commander can the tps be going bad. Is there a way to check it?
It will bounce around at idle, if it's doing it more than just at idle you probably have the same issue I did. I talked to the techs at power commander and they said it's due to a bad ground. Call dynojet and ask for Kyle, they just released a wiring harness that will solve the issue and you can send it in and they will do the swap for free. :thumbsup: I had my shop warranty me a new tps first and that didn't solve it so if your bike is no longer under warranty I would try the new wiring harness before shelling out the cash for a new TPS.
I don’t have pc3 but I have had a tps go bad and there is no mistaking it......it was damn near unrideable.
Thanks I will get in touch with PC.
