I'm doing the install on my voyager now and in the instructions it says run the red+ after the capacitor, well I'm not sure where that is on this, I looked through my shop manual but didn't find an answer.
Or do you guys just hook it up to the batt directly or is there a easy location I can tap into
I connected my voyager directly to the battery positive side, works fine. Just be careful where you mount the voyager. I used the mount it came with and put it on my handle bars next to my throttle. It kinda stuck up a little - bad spot. I rolled my quad and damaged the joystick, but on a good note trail tech warranted it - no charge! they are awesome. Now I have it mounted right to the plastic dash switch holder (just drilled 2 holes in it) so far so good.
Yup connected direct to the battery
