Im planning on getting some hardcore engine mods for my rappy this summer should i go ahead and trash the dobeck? ::)
There are a few people on here that have some nice engine mods and still run the Dobeck just fine. I say if you are going pretty big then to get the most out of those mods I would upgrade to a pcIII but I am sure the Dobeck could handle it.
If your going to build a 4 mil or 6mil 105mm bore stroker then yes i would reccomend selling your dobeck and going to a PCIII. If your going to build a stock bore with upped compression P&P and a stage I or II cam then I would say try the dobeck out and see if it will allow you to add enough fuel to dial it in. If it won't then you will need to send it of to doebeck to reprogram or if you don't want to do that then get the PCIII.
Randy
