Hello folks. I recently bought my son a 05 TTR 125 used of course. Problem I'm having is it bogs down when I gas the throttle quickly if slowly accelerating it's fine. I've replaced the carb with 1 from Ebay that looks the exact same as the 1 I took off. Still same issue....any hell or advice is greatly appreciated
Did it bog before you did the valve adjustment? Are you still having the ticking problem?
Put your choke partly and see if the bog gets better or worse. You can play with your mixture screw. Or change your needle position up or down. Make one change at a time and keep track what you did. Change it back it doesn't help.
Deal with the pilot jet too for bog, what do you have in there?
