Anyone know if there is a good tubo kit for the rappy?
I think you may want to do a little more research. The short answer, no. Carbs and turbos are not a good combo, and you would not want a high compression piston if you made a turbo setup for the old 660. Plus i would not trust the stock rod.... they are know to go with just 686 setups. It would be cheaper/better/easier to sell the 660 and buy a 700 and bolt a turbo setup to that. A reliable 700 turbo setup is going to put you back $3-4K...
+1 there was never a quality kit put out for the 660 with any kind of reliability and gains worth doing. You're best off doing a strong N/A build, or - if you're set on wanting a turbo, buy a 700R as Monty suggests. Also as he said, a good turbo setup will run you about the price of a full quad, $3500-6K depending on what you want.
Ya, just found some older posts on here about the waste of time. Sorry for the repost guys.
mr.turbo makes them but like the other guys said.....its like throwing eggs at an abortion clinic.....it might sound like a good idea but it doesn't help anything
Mr Turbo still does the kits, or at least they're still on the website.
KMS had a decent kit with fuel injection conversion.
There were others, but not really worth mentioning.
