1 - 16 of 16 Posts
So I put my ordered my turbo kit with the second injector , boost gauge , boost controller , lockout clutch , extended swingarm , and extended brake line . But I cant decide on a 5mm stroker or port polish and bigger valves, tips? advice? thanks in advance
i don't think a port and polish will help that much as your engine should be getting air pushed into the engine, rather than your engine sucking air in.
i think you should do a stroker, and or a big bore
You should ask the builder that is doing your turbo kit. I would do a larger bore Before I stroke it but you could benefit from a good rod as well. What are you building this quad for? Racing only or just riding? If it's a rider the standard kit should be more then enough.
Thats a good point, but I'm not sure 100hp sounds kinda weak ... Def joking, I'm gonna wait but still looking for ideas rather be ready than not
Discussion Starter · #14 ·
SB/SS ? help me out with that one , but I did get a +8 swinger to help keep the nose down so a lighter axle?
Did some reading , Stock Bore , Stock Stroke ... Thanks Bob
1 - 16 of 16 Posts
