1 - 15 of 15 Posts
i bought this from RMatv and when i stand my bike up it leaks out of that straw. Is this suppose to happen or what?
It's an open vent, so yep... If you're going to stand it up, make sure your tank is low or that you pinch that hose shut with something.
This is why the stock gas cap hose goes up to the steering stem. It keeps the opening up above the gas tank, so you get no syphon effect.
thanks alot man
shouldn't those things have a check valve on them? air goes in, not out?
u r right that it should have a check valve on it. mine does and it does not leak at all. I wouls call RMATV and talk to them since that is where I got mine and it came with the check valve
Raptor_Ryder7 said:
Mine ddn't come with a check valve. I just put the stock cap on when I stand it up.
did you buy yours from rmatv too?
I purchased the 7 dollar vent tube from RMATV made by Tusk and it is checked
isnt that the same one that comes with the tusk gas cop
Yeah, I purchased mine from Rmatv and it came with a check valve and vent tube. Not to mention i got it for 25 dollars and you see ppl on ebay charging 30 plus for them.
u should contact them and say :wtf:
so should i call them back and tell them it leaks when i stand it up or what. Whats this check valve thing, is located the tube thing or is it actually on the cap?
it should have come with the cap. it is a small check valve that goes on the end of the hose.
[/quote
yea that piece is on there and that where it leaks out at. So should i call them and see it they will send me another hose?
1 - 15 of 15 Posts
