1 - 2 of 2 Posts
I took my quad in at about 25hrs to have the valves adjusted, then I had the 10.5:1 piston and stage II CAM installed at about 65hrs. Should I adjust the valve clearances again after the piston install because og the higher compression, or just wait until the 100 hour mark?
They should have been adjusted according to brand specifications when the new cam was installed.
1 - 2 of 2 Posts
