got 14 days left in afgan, when i get back im tearing my 07 apart i got the 11:5:1 piston and hot cam 3. im thinking of getting the kibble white stock replacement valves and their valve springs. of should i regrind the valve seat to go +1 or +2? is there much of a gain from them? thank you for your imput
Cola Crew
You are working on a good combo.. I would look at having the head ported and going +2 so that it's done. Do it right the frist time..
If you are going to spend the money on a spring kit, I would recommend going with a more aggressive cam than just the stage3 hot cam. As for valves I would put the Ferrea +1 valves instead of the Kibblewhite valves.They will live longer. If you are pulling the head it would be worth the money to have it ported as well.All together it will make a big gain in performance !!! Let me know if you are interested I can make you a package deal on all of it.
