1 - 2 of 2 Posts
alright im pretty sure i figured out the speed sensor and of coruse the temp sensor but im trying to figure out the rpm's on where to connect it to...???
im not sure where to hook up the red to the two coil wires either the top or bottom one. and will this give me the most accurate reading? where did u put your rpm wire?
also the ppr was said to set to .5 which i did but not sure what to set the pulse to??? will is automatically figure out the pulse?
and the wheel size lol.. do i set it to the 1676?
and lastly the high temp light and the danger point temp settings? if i can rember the fan kick on at about 135 right?
any help would be great.
Discussion Starter · #2 ·
:bump: i have it apart and leaving tomarrow to go try this thing out. noone knows?
1 - 2 of 2 Posts
