I have a 06 Yfz450 and i cant find the VIN number on it. In the manual it says that it should be found beside the gear lever but there is nothing there. I have been told that the fram was the original by the previous owner.
Is there anywhere it could be ? And how many digits should it be ?
Thanks
Has the frame been powdercoated? If it has, it maybe hard to see it there. If it is stock paint on the frame, it should be right there where the manual says...
The vin number should be 16 digits...
If you can't find the vin at all, its a replacement frame most likely...
Thanks
Left frame rail below the engine.............
If you have a skidplate on there, you may need to remove it to see it.. The GYTR skid covers it I believe..
