Voting for May ROTM
  • Rap660
    Votes: 7 19.4%
  • brettjsand2000
    Votes: 26 72.2%
  • 03rappy1987
    Votes: 3 8.3%
RaptorPilot
http://www.c2powersports.com
Voting for ROTM to take place from 15th through the end of the month.
Here are our Finalists for ROTM.
The winner wins a Lifetime Premium Membership from RAPTORFORUM.COM!! PLUS a really cool gift from C2Powersports.com
Great turn out this month and if you did not make the Finalists list please try again next month.
Good luck guys !!!
1st Rap660
-2006 Raptor 700-Dynoed 65whp
-CNC ported and polished heads (KDS Racing) with +2 valves
-Hot Cams Stg 3 cam
-11.1 JE piston
-Power Commander 3 (custom dyno tuned)
-Dynatek Programmable ignition (current set on 2)
-GYTR Intake and filter
-MonsterPipes Dual exhaust
-KDS Racing Evac Valve
-CCP Steering Stabilizer
-15T Front Sprocket
-G-Force Rear hub extender
-Renthal Bars
-CFM Oil Tank
-ASV Levers
-Tusk grab bar
-Rock Nerf bars
-Tusk Case saver
-Inline water cooler
-08 Resi shocks
-GYTR bumper
-Blue drip graphics
-Pro Elite PB Block off
-inline Water temp gauge
2nd brettjsand2000
2007 Raptor 700/780
+2 Cuervo Head
+5 H.R. Crank
HDD 5050 Cam
WK 54TB
11:1 CP Piston
Boss Noss Nitrous kit with a 20 shot
Pingle GOGO button
Monster Dual Pipes
PC3
Dynatech with DL700 curves
Direct Drive Lockout Clutch
+8 Fireball Swingarm
Fireball Play/Drag Axle
Pro Taper Bars
ODI Grips
Houser Steering Stem
Terry Cable Throttle
Dr. D Reverse
Pro Taper Grab Bar
WiigStyle Rear built shock
ModQuad Flame Case saver
ModQuad Gas cap
Custom Ostrich Quill Seat
Custom HDD/Cuervo Graphics kit​
RaptorPilot
Discussion Starter · #2 ·
3rd 03rappy1987
Mod List:
-DMC Force 4's
-PC III
-FCI w/o Box
-+3 TB
-Pro Taper Bars
-Maier Plastics
-Quad Tech seat
-Pro Armor Nerfs
-Pro Armor Pro Grip pegs
-RPM Dominator Axle
-ModQuad PB Block off
-Pro Armor Bullhorn
-Pro Armor Radiator Guard
-UPP Case Saver
-DFR Graphics
-+.5 Houser Slicast LT A Arms
-Triple Rate LT Elkas
-Skats and Front Sand Sharks​
"Sand Hustler"
Good luck guys !!!
1st Rap660
-Hot Cams Stg 3 cam
-11.1 JE piston
-15T Front Sprocket
-Renthal Bars
-CFM Oil Tank
-ASV Levers
-Tusk grab bar
-Rock Nerf bars
-Tusk Case saver
-08 Resi shocks
-GYTR bumper
-Blue drip graphics
2nd brettjsand2000
2007 Raptor 700/780
+2 Cuervo Head
+5 H.R. Crank
HDD 5050 Cam
WK 54TB
11:1 CP Piston
Pingle GOGO button
Monster Dual Pipes
PC3
Pro Taper Bars
ODI Grips
Dr. D Reverse
Pro Taper Grab Bar
ModQuad Gas cap
