1 - 13 of 13 Posts
I DYNOED the bike using both of the fuels above, and here are the results:
VP-113
PPG= $10.50
HP= 84
TQ= 59
Smells = nice and sweet
MR-12
PPG = $22.00
HP = 87
TQ = 61
Smells = strong and must be kept isolated
So there you have it, you have to pay the price to get max HP.
Ridin High.....
little bit lean on the MR-12? dunno about double the fuel cost for 1HP
I was going to say a bit rich on the VP-113 and about right on the MR-12. Just my 2 cents, but A/F ratio's may have played just as much effect as the fuel itself.
Nate
Alba Racing
I richened it up a bit by the end of the day. A/F at 13.2 to 13.4 through most of the top.
Conclusion:
USE MR-12 for race day. (3HP and 3 FT/LBS of TQ) can win a race. Top speed was 108
Use VP113 for everyday riding. Top speed 106.3
Conclusion:
Using the same map for both fuels or custom tune each?
That's good info. Thanks for posting it up.
used 2 different curves on the DYNATEK. The maps changed slightly, but just because i wanted to get more HP. You should be able to run same map for both Fuels.
I will by trying the U4.4 which is a cheaper fuel than the MR-12. Oddly enough, the Octane on the MR-12 is 87 and the octane on the VP113 is 113.
87 wow
The MR-12 is 87 motor octane, it's R+M/2 is 93 octane which is about the same if not better than premium pump gas in most areas.
The VP113 is 109 motor octane, 118 research octane, 113 R+M/2
For those looking in, the octane number on your corner gas station pump is the sum of the research octane number and the motor octane number divided by 2, typically written as the R+M/2 value.
Keep the different types of octane measurement in mind when comparing fuels.
Sand Slinger Extraordinaire
Thanks for sharing!
Although I don't run, or intend to run either of these fuels, it's always nice to see back to back dyno comparisons on different "components", be it parts, fuels, or whatever.
Thanks, def do a comparison with u4.4 since iam gonna run it this year. Good info
1 - 13 of 13 Posts
