When i ride for abouyt 1hr or so the light will flash...if i turn it off for like 2 min it'll go away until i ride for about another 15mins...fluid levels are all good! Any help appreciated!! thanks
recovery is like 3/4 full..havent checked for bubbles...any other things i should check for?
Does it happen when you are in neutral? If it does, when you shift a gear does the light go out, and have you ever taken the dash off of the Rappy?
yes ive taken the dash off before...i didnt no if it misreadin that its hot or what...cause the power is the same...no loss in power
If all the level are good, it might be your thermostat. Take it off and put it in a container fill with very hot water. Put your thermostat in it and look at it. If it does not open then you find your problem.
