1 - 9 of 9 Posts
The pumps leaking from the weep hole. Did a search for "Water Pump Leaking" and it came up with 3 threads. 2 were no help and the one mentioned it might be the impeller seal, called the mechanical seal on the schematic.
Have not pulled the pump but think this may be the problem?
Water pump seal is leaking internally................:)
Water pump seal needs replacing.
This would be the seal behind the housing on the impeller shaft, correct?
I would probably replace both seals and the bearing. That way you have everything covered. I cant remember if one part number is for both seals or if you have to order them seperatly.
I would just change the pump, your only talking $35 or so. Pump part #5LP-12420-00-00 and oring #93210-77363-00
I was just going by what the parts list I have and in the past it has been about $5 off. this is the print I have and it does not show the seals. but this one does show it.
1 - 9 of 9 Posts
