Hi, My 700 is leaking coolant out of the breather line so I think I need to replace the mechanical seal in the water pump assembly, Does anyone know where i can order just the seal? Or possible the whole assembly? I need to know ASAP because were planning on going to dumont next week and need to have it fixed!! Thanks.
VALVE DROPPER
Its gonna be tough to pull the bearing that the seal sits behind IMO.. If anyone has replaced this seal can you give insight on how you pulled the bearing?
I am sure bike bandit sells that seal... Ebay has water pumps..
Goodl luck and hope you get it fixed soon..
rockymountainatvmc dot com is where I got mine
