After doing some research i have found that my water pump seals are bad.
I have small drops of oil in radiator fluid.What parts do i need to fix this?
Also what is the best way to flush the radiator to make sure i get all the oil out.
Thanks for the help.
I usually use a dishwasher soap used for dish washers to clean the cooling system.............
Replace the seals. Make sure you install a new snap ring that holds the bearing/seal assembly. Flush the radiator with strait water and a hose.You could use radiator flush. Refill with proper colant. Try e-bay for seal kits. Fich files for parts can be found from most vendors. Try Cheap Cycle Parts. Good luck
Whats the best way to get the mechanical seal in? Ended up braking part of the black plastic on it.I have a new one ordered and dont want to break that
to.Any tips.Thank you for the help.
