Do you mean how does an ignition system work, in general ???blackraptor said:Hi, can someone explain what exacly the ignition system does? A link maybe?
Thank you :thumbsup:
Do you know if they ship stuff out or are they just pickup only? Is there more than one grind for the cam or do they only have one?Grizzlygreg said:Hey Newbie, I just had a web cam installed at one of the non-dealer atv shop in El Reno, OK called Phil's atv and cycle. Then I had them put it on the dyno. 45hp at 1400 feet above sea level, not bad. I have the LRD pro 4 exshaust and the dynojet powercomander111 controler, plus a K&N pro flow air intake and last a 15 tooth front sprocket. So far I can beat the 450's with only slight modificdations. Think the web cam is great.
Is it in production yet? Who makes it. Is the timing adjustable by rpm increments, or just a basic timing setting? How far retarded can you go with the timing?sparky yfz said:This is one of the ignitions that the Rocket Factory and I are testing. This thing has any feature you could want
NO SPEED LIMITER
lanch limiter
shift limiter
NOS staging
NOS progression
tach output
shift light
fully adjustable timing curves
fully adjustable fuel maps
complete run back info
plus much more
yeah so much for camshafts huh. but who cares i wanna hear more about the ignition anyways...how does it plug into the 700?135boom said:kind a funny that a topic called "web cam" has turned into an ignition topic...haha :thumbsup:
haha.....yeprappy_700 said:yeah so much for camshafts huh. but who cares i wanna hear more about the ignition anyways...how does it plug into the 700?135boom said:kind a funny that a topic called "web cam" has turned into an ignition topic...haha :thumbsup:
